Drill to power winches
Beneteau 323 Annapolis MD
I measured my winch handles today, and it would take an 11/16 square stock to fit the winch socket. I'm going to see if a local metal shop can make the adaptor at a decent cost.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Make sure they make the shaft to the bit TRIANGULAR, so it doesn't slip in the chuck.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Well I fit the Cranker bit into my 3/8 right angle Ryobi this weekend. It was a tight fit, but made it. I tightened it and took it to the boat. The square end fit my Lewmar 40ST fine and spun it without a load no problem. I didn't have more time to play with it than that, but wanted to provide some update.
Jan 22, 2009
133
Hunter 31 '83_'87 Blue Water Marina
Got a DeWalt and a Cranker.
Runs the mainsail up pretty good.
Don't run the sail up and down a lot when I'm out, so the battery life is not really an issue.
I've been looking at options to the commercial-made adapter bit. First thought: My local metal shop did not have a square bar stock, but could get it. He said one piece would be expensive to set up. More pieces, the cheaper per each. Second thought: Sears and others have an extension bar for 3/4-drive seckets. The shortest was $25, but a used one from a flea market would have to be somewhat cheaper. Grind the 3/4 square down to 11/16, cut off the socket end and grind the 3 flats onto it. Third thought: McMaster Carr has 11/16 square stock in a number of different metals. A foot-long piece can be had starting at 6 dollars or so. If you make a jig, you could grind down to round for 4 adapters- before cutting the stock.
Ross
Jun 15, 2004
14,693
Really how many turns do we need to make with high torque levels?
BobM
Jun 10, 2004
3,269
I have to agree...
Unfortunately, that appears to be poorly designed from an ergonomic standpoint. Most human wrists don't do very well resisting torque in the lateral plane as the wrist... and it would have made far more sense to have the handle be vertical rather than perpendicular to the winch.
When I tried out my 3/8 right angle Ryobi it seemed like it would make a darn good winch handle even if the battery was dead. It is about 18 inches long. I think it will be good for everything but raising someone up the mast.
Oct 22, 2008
3,502
Yes, because the handle on the Ryobi is parallel to the winch drum axis, giving you fairly decent leverage when the drill tries to twist out of your grip.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
I guess we'll soon see, it got high marks at the Miami boat show, winning the innovation award.
I would agree about the handle if you were standing over, on top of the winch, but the handle ergonomics make sense to me if you're off to the side of the winch, like in the cockpit.
Oct 22, 2008
3,502
Dave—
Even if you're off to the side in the cockpit, the design is flawed. You have a lot more strength in your wrist perpendicular to the palm than you do working in the plane of it.
I'd also point out that the palm being oriented vertically is a more natural position for the hand than it is with the palm oriented horizontally. If you hold your arm by your side and the raise your forearm... the hand is oriented vertically—not horizontally.
As most cockpit winches are mounted on a horizontal surface... the WinchRite's grip is in the more unnatural of the two positions as well as using the weaker muscles of the lateral wrist. This is simple ergonomics—it is not well thought out. And IMHO, if they haven't bothered to do the basic ergonomic research, what else have they overlooked.
I'd also point out, that if the winch is heavily loaded, the torque on the WinchRite will tend to twist it out of your grip. If the handle were vertical it would try and move the handle, but it wouldn't be twisting out of your grip.
Ross
Jun 15, 2004
14,693
Years of experience are reflected in the shape of handles. Cranks are made to allow the best transfer of muscle to handle, luggage handles are made for lifting but not for turning. Wrenches are made for efficient pulling, this tool has a luggage handle.
Oct 22, 2008
3,502
Well said Ross... exactly my point...
BobM
Jun 10, 2004
3,269
There are other pluses to the right angle drill approach too.
(1) You have a cordless drill on board for other tasks.
(2) You likely have other cordless tools you can use the 12V charger you bought for it for. In my case that means I can use a dozen different cordless Ryobi tools on board...and even more should I buy them. Some make a lot of sense on board, such as the vacuum, sander...etc...there is even a portable fan and a caulking gun. Probably don't need the chainsaw though, unless I need to cut the rig down LOL.
(3) If I drop it overboard I am out $130 for the drill and cranker bit plus the cost of a battery...say $180...or less than half of the dedicated unit.
jybiom
Jul 10, 2004
28
Catalina 30 Erie, PA
winchbit
We have used this, http://tinyurl.com/ylcup64 With great success and the winchbit on our Mariner 40 ketch. We still have it, the battery charger and one battery and now own a trawler so no longer need it if anyone is interested. Chuck
Chuck. Im 66 and would be interested in the unit you describe. Where are you located and how much would you want for the unit?
Thanks,
John
Oct 22, 2008
3,502
I asked Sailology, the makers of the WinchRite about my concerns and here is their reply:
Thanks for your email and your opinion. We always welcome feedback.
A few points to your email:
- We specifically designed the WinchRite to pull away from you to avoid injury, damage to the unit, or winches. With this design you cannot over torque the Winch, the unit or your arm. This is a safety feature of our product.
- We have many years of experience using the converted drills on our boats and found them heavy and in some instances very dangerous. They require 2 hands to operate, retaining screws snap and you can damage your winches. Drills are meant for drilling holes, not turning winches.
- The WinchRite matches or exceeds the Maniwell in power and functionality.
- The price is actually the most competitive for a cordless winch handle. The Winchbuddy sells for $899 and the Maniwell sells for 2200Euros or $2900.
We realize that the WinchRite is not going to be for everyone and some sailors prefer the manual handle. I suggest that you wait until someone near you purchases a WinchRite and try it out for yourself or visit us at the Oakland sail show.
Thanks again for your feedback.
Best regards and safe sailing,
I'd point out that most cordless drills have an adjustable clutch, so you can easily limit the force that they can apply. I'd also point out that you can get a decent cordless drill for far less than $550 they're asking.
Ross
Jun 15, 2004
14,693
Translation, We know the handle design is lousy but this is how we explain it. Winches can be assembled to work in the other direction. My two speed winches require the handle to turn either way but the pawls only allow the drum to turn one way. Is this tool reversible for two speed winches?
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
I'll reserve my opinion until I have a chance to use it, I hate rushing to judgement before I give something a chance.
