G
George Fletcher
I would like to mount deck hardware for a boarding ladder I purchased from West Marine. It requires mounting two "keyholed" stainless steel plates on the deck on both port and starboard decks at the pass through areas in the lifelines.Before I go boring holes in the deck and possibly causing future headaches I would like some advice as to HOW to PROPERLY drill the holes (4 in each plate) to accept a #12/14 screw, and HOW to PROPERLY seal the holes to avoid water penetration of the core.Should I us machine screws or pan head sheet metals? Do I need a backing plate? What do I use to seal the holes so that the deck core does not take on water?I purchased this ladder to avoid the gymnastics of trying to reboard the boat at the fuel dock or pump out. As I get older the freeboard seems to get higher and higher.Any sugestions to keep me out of trouble and to avoid future deck problems would be appreciated.
