How/what is the best way possible to clean up dried cetol from a boat deck without harming the gel coat?
Cetol dripped from the wood on to the plastic of the boat and has dried. Idk how to clean it off without scratching/damaging the boat…In what way is the Cetol dried on? Do you have drops and drips, or is it coating the deck?
In the case of discreet drops of Cetol, try a small sharp blade to cut the drop carefully apart from the gel coat, otherwise, you may have to spot repair the gel coat after removing the Cetol with a solvent or sand paper.
-Will
Acetone may work, as long as it doesn't stay in contact with the gel coat for an extended time. It evaporates pretty quickly, so not usually a problem, but acetone will soften resin coatings.Acetone works for me, haven't had to scrape it off or caused any damage yet.
