Dried cetol
Apr 11, 2023
2
pearson 323 federica yacht club
How/what is the best way possible to clean up dried cetol from a boat deck without harming the gel coat?
In what way is the Cetol dried on? Do you have drops and drips, or is it coating the deck?
In the case of discreet drops of Cetol, try a small sharp blade to cut the drop carefully apart from the gel coat, otherwise, you may have to spot repair the gel coat after removing the Cetol with a solvent or sand paper.
-Will
dmax
Jul 29, 2018
1,316
Telstar 28 Buzzards Bay
Acetone works for me, haven't had to scrape it off or caused any damage yet.
2
-Will
Cetol dripped from the wood on to the plastic of the boat and has dried. Idk how to clean it off without scratching/damaging the boat…
Acetone may work, as long as it doesn't stay in contact with the gel coat for an extended time. It evaporates pretty quickly, so not usually a problem, but acetone will soften resin coatings.
-Will
Jan 26, 2019
70
Catalina 30, mkI 2462 Waukegan, IL
The gentle heat method is a great idea as that's how I remove older layers from my teak.
I get a few small drops on the gelcoat when I do my annual maintenance coat. I use a dental-style pick (hardware store. . . . like a dental pick but larger). Carefully pick at only the Cetol and don't scratch the gelcoat. Lots of times it will kind of pop off. Experiment with how you use the pick--sometimes the curvy "neck" portion of the pick (and not the pointy scratchy end) works. If this curvy portion marks the gelcoat it tends to be a scuff and not a scratch.
