The specs show that this model
comes in two keel configurations; one a shoal keel of 3.3 ft and 3,200 lbs ballast and the second a keel of 4.3 ft and 3,000 lbs ballast. The leaverage of the longer keel needs less ballast weight. The model with the longer keel will point better into the wind but the one with the shoal keel can safely get in and out of places the other one can't. Here in Florida, because of shallow waters shoal keel draft boats command a premium. I would suspect Louisiana is similar. We have a 1983 with the 4.3 keel and we don't have a problem but a couple of times a year. It is when you get close to 6 ft that it could seriously limit the use of the boat. Don't trust a seller's representation of actual draft, pay to have someone measure it.
