Draining the heat exchanger on the 3GM30F
Doug A
Mar 19, 2007
5
Beneteau 36CC Pawleys Island, SC
Hey Guys - My Yanmar 3GM30F engine manual says that I should change the fresh water every year AND that there is a drain plug on the side....I have pulled several bolts out but none were the drain plug. Has anyone been successful at this task?
GuyT
May 8, 2007
406
Hunter 34 South Amboy, NJ
You mean the anti-freeze coolant?
The anti freeze engine coolant drain valve is on the port side behind the alternator. There should be a clear hose attached. If you mean the fresh water supply to winterize the engine, that is on the starboard side and it too has a clear hose attached - kind of between the mixing elbow and the fuel filter. You should get a Clymer book or equivalent for many answers about your Yanmar Engine.
Doug A
Mar 19, 2007
5
Thanks
Hey, Thanks Gemini I fully agree that the Yanmar Manual is inadequate and I was wondering if there was a user-friendly publication that could fill in all of those dead spaces. Thanks for the suggestion on Clymer book. I will be sure to buy one. The one petcock that I have used is on the aft end of the heat exchanger. It has the clear plastic hose and I must have drained two quarts out of it but the water-level in the coolant reservior tank (on the bulkhead) never went down - so I figured that what I was draining out was river water. I will not investigate the port-side of the engine (which is very crowded and pushed against the bulkhead) for that other petcock. Thanks again. Doug Anderson
