My Yanmar 3GM30F just stopped running. The repairman said it was water in the fuel and the injector pump and injectors needs to be rebuilt. He is taking care of that but he said I should drain the fuel tank and add a fuel separator. I am looking for recommendations on both the type of fuel separator to purchase and well as the procedure for draining the tank. I'm guessing to drain the tank I should buy some type of pump from West Marine, pump out all I can, remove the tank, then visually inspect it to make sure there is no water or gunk left in the tank.
Thanks for any advice.
