I Find the design of that locker behind the folding transom questionable. That storage always gets wet, because any water from the cockpit ends up there. This is true when we are washing the decks, or anything else, so a lot of debris and dirt goes that way. The drainage is supposedly gravity fed to the sea, but I have never observed that actually work without a lot of help from me. At first I thought it was plugged or the thru hull closed. Turns out it has a siphon effect, and it never drains because the thru hull is not right below the drainage hole and the hose has to make an odd curve.
Have any other oceanis owners run into the same problem, and what is your solution? I end up having to open that up every time the boat is washed, put a hose with some water pressure through the drain to get the flow started, then wait for the water and all the crap washed off the boat for the last couple of weeks to drain through, and repeat a couple of times.
Let me know if you have any suggestions. Thanks!
