Hi all,
I am eager to redo my "shower" in a more proper manner. Currently, the water drains into the bilge through a slatted floor (or "sole" i believe in sailors terminology, make of Trex decking. I lifted up a piece for the pictures). This rests on tabs against the hull, and side bulkheads.
The problem is how to design the space to create a shower pan with a single drain that leads into a holding tank. Does anyone have any ideas? Pictures of a shower with a toilet in such a small space?
The boat is a 1960s Rawson 30'. There is a manual Jabsco toilet that pumps through the bulkhead on the left into a Lectrasan tank. There is room in that space for a holding tank, but I don't know how to build a shower pan that collects the shower drain water and plumbs it "uphill" in such a manner. The space beneath the current slatted floor is very small, probably too small to have the holding tank under it.
What I've considered is to raise the floor level enough to put a holding tank underneath, though I may end up crouched and I don't know if the toilet would fit anymore.
The bare fiberglass hull is visible under the lifted floor panel. Above that, the hull is insulated with some foam and finished with FRP (fiberglass reinforced panels) typically used in home construction. The toilet sits on a wooden box merely for usability comfort.
