Drain/holding tank for small shower
Aug 3, 2021
6
Rawson 30 Juneau
Hi all,
I am eager to redo my "shower" in a more proper manner. Currently, the water drains into the bilge through a slatted floor (or "sole" i believe in sailors terminology, make of Trex decking. I lifted up a piece for the pictures). This rests on tabs against the hull, and side bulkheads.
The problem is how to design the space to create a shower pan with a single drain that leads into a holding tank. Does anyone have any ideas? Pictures of a shower with a toilet in such a small space?
The boat is a 1960s Rawson 30'. There is a manual Jabsco toilet that pumps through the bulkhead on the left into a Lectrasan tank. There is room in that space for a holding tank, but I don't know how to build a shower pan that collects the shower drain water and plumbs it "uphill" in such a manner. The space beneath the current slatted floor is very small, probably too small to have the holding tank under it.
What I've considered is to raise the floor level enough to put a holding tank underneath, though I may end up crouched and I don't know if the toilet would fit anymore.
The bare fiberglass hull is visible under the lifted floor panel. Above that, the hull is insulated with some foam and finished with FRP (fiberglass reinforced panels) typically used in home construction. The toilet sits on a wooden box merely for usability comfort.
The shower sump doesn't have to be very big. The one on my H356 probably held less than a quart - maybe a lot less. The key is to have a sump pump which empties the sump as it fills. You can probably find an after market sump and pump but making a version won't be that hard.
You need a plastic container (Laundry soap container) which you can modify to fit almost any space. You can place a small pump in it with the appropriate electric and discharge connections. You don't need a 1200 gallon per hour pump. I think self priming would be best. Then you have to clean it regularly since soap, hair and discarded skin cells make a smelly mess if allowed to co-habitate.
+1 for the sump pump. It should be possible to do that using just enough space for a sub-floor drain tube and a very slight recess for a drain hole in the lowest section of the pan. There are shower sump pumps that are pretty resistant to clogging, and a separate screen filter can be added too if necessary, all above and away from the shower pan.
Is there any reason you want to use a holding tank and not just pumping the gray water overboard? It’ll save space to not need a tank, even if you can put the tank elsewhere.
Jan 7, 2011
5,864
Oday 322 East Chicago, IN
In addition to the shower sump idea, another alternative is a shower pan, with a drain connected to a pump directly ( no sump per se). My O’Day 322 is set up that way…the shower pan has a drain and hose connected to a pump in the vanity, that pumps overboard. I think this method was used because I have no room under the shower pan…just enough for an elbow under the drain. The own side is I have but turn the pump on and pretty much keep it on while using the shower. There is an on/off switch in the head, so easy to turn the pump on and off. My set up uses a diaphragm pump, which is pretty loud.
It seems like either way, you need to fabricate some sort of shower pan, so you can capture the water into a sump box or the hose connected to a pump...unless you can just close off your bilge under the shower so the water stays there, and you can fit a pump in there to evacuate it reasonably well.
Greg
Dec 2, 1997
9,009
- - LIttle Rock
There are two places you DON'T want shower water to go--the bilge and your toilet waste holding tank...in fact, it's actually illegal to put it in the holding tank and t he bacteria, soap scum etc in shower water will give you a very stinky bilge. So the suggestions to install a shower sump with sump pump are good ones. You may just have to plumb it to put the sump somewhere near the shower drain instead of directly below it.
--Peggie
Aug 3, 2021
6
Rawson 30 Juneau
Wow I appreciate the replies! Controlling the bilge stink is my motivation for this project.
I do not "need" a holding tank. I thought it would be on the less legal side to directly pump my shower water overboard. Of course that's what is happening now by draining into the bilge. Maybe it's not clear in the picture, there is currently a small bilge pump in that space below the shower floor that pumps into the main bilge compartment. I could reroute this hose directly overboard, but that would still leave a difficult to clean space underneath that would get stinky. Currently I wash this area (and the main bilge) about once a week, because of the stink. But of course these are difficult to clean areas, and the porous cement never really gets entirely clean.
How would you go about fabricating a shower pan for this space? I'm imagining replacing the slatted floor with epoxied wood or some plastic/synthetic material into which I've drilled a drain in a low spot, which is plumbed directly overboard, via an inline pump. I have an unused seacock next to the toilet, but to use this would mean the drain hose would have to come back up through the showerpan floor to get overboard, so a sort of U-bend to reach the sea cock next to the toilet, and an extra penetration through the showerpan. Or else take a much longer route through the bilge and T junction in to the overboard bilge hose?
And how to attach this pan in place? Epoxy to the tabbed sides so it cannot be removed?
Currently the pump switch for this compartment is in the head so rewiring is very easy.
6
Rawson 30 Juneau
Wow, very cool what he did. I don't see where he's going to run the drain hose from under the showerpan, or attach a pump, but regardless, I think his skill/time/effort/space to work far exceeds what I am capable of. I'm hoping to use some plastic sheet (like a solid surface countertop?) as the showerpan so I don't have to lay so many layers of fiberglass ontop of plywood. Though I won't get such a nice fit, I do like the idea of using several pieces puzzled together to create a nice slope angle.
Thanks all for your support, great info so far.
Aug 3, 2021
6
Rawson 30 Juneau
Well I didn't get around to this project last summer, I'm just starting now though!
I want to be without a shower for as little time as possible, so I'm waiting for the Whale gulper 220 that I ordered to arrive. I'll mount that before taking out the existing floor and working on placing in new plywood ensconced in epoxy and fiberglass with a little drain that connects to the pump.
I haven't exactly decided how I will discharge the pump. I'd rather have a long run alongside the bilge line to discharge above the waterline from the aft engine compartment. But, I'm concerned the pump isn't made for such a long run (20ft or so horizontal, 2-3 ft vertical. I asked Whale customer support and they agree), and also I'd rather not drill anymore holes in the hull.
There is an unused "seacock" (straight ball valve right now) below the waterline through hull in the head that I may use, the one on the far right in my original pictures, with the white cap on it. I've now removed the toilet, and found the water intake ball valve I was using for that leaks (the middle one in the picture, the lower 3/4"). So I removed it and capped it for now...I'd like to replace both those 3/4" with a proper flanged seacock with a backing plate. The 1.5" seacock is well done already.
I'd like to enclose all those seacocks...previously I insulated around them which bothered me because I could not inspect the base. I'm glad they all seem in good shape, the leaking ball valve spun off without issue and the through hull looks good.
I'm thinking of building a box with two pieces of plywood (and epoxy and fiberglass) to box them in with an access hatch. I'm doubting whether I'll put the toilet back in, because with that box in place, there won't be much space, and I never liked having a wet toilet after showers. I have a dog, plenty of poop bags, and squats are good exercise. But I have the Lectrasan unit and toilet so I'd hate to waste those. We'll see.
Alternatively and maybe the what I will do "temporarily" for the shower pump discharge is use the above the water line through hull in the head that was used as an air vent for the anti-siphons valves for the toilet (red hose in the picture below).
Priority first is get the showerpan and pump working then moving to figure out how to insulate around those seacocks, and probably replace the rest of the insulation against that part of the hull in the head (currently a layer of Reflectix, about 1.5" of styrofoam, and FRP panel on top. Probably waterlogged).
I'll keep you updated, in hopefully less than a years time. Any suggestions appreciated.
5,864
My O’Day 322 shower pan has a drain, and a hose connected to the drain. There Is very little clearance under the pan.
The hose is routed to a diaphragm pump located under my head sink cabinet and from the pump, out an above the water line thruhull under the sink. This is a very short run.
Not sure why you need a 20 foot run to get out of the boat (but I am not familiar with your boat layout).
Greg
Aug 3, 2021
6
Rawson 30 Juneau
That sounds like what I'm going to do. The pump will be behind the bulkhead on the left with the Lectrasan.
The reason I *wanted* the long run to the aft was 1) it would actually be easier, to route the hose through the bilge alongside the existing bilge pump line, than to drill a hole in the sole to have the discharge line come back up and 2) it would keep the line out of sight; the short run discharging from the head will be forever visible and get wet everytime I shower. If I end up not reinstalling the toilet, there will only be 1 hose in the head, and that's the shower discharge. It'd be great to have none.
Aug 3, 2021
6
Rawson 30 Juneau
Progress!!..?
Old floor removed, surfaces cleaned and dry(ing), sanded (boat filled with dust), epoxy sitting ontop of the water heater to stay nice and warm, new sole piece dry fit and edges soaking in epoxy.
The stringers under where the sole will sit are soft :( I am not confident in my ability to replace those. No idea how, they are embedded in the concrete, and can't access the other side without tearing up more sole. I'm leaving the dehumidifier and heater in there for a while longer to see if they'll dry out, and will likely inject some epoxy throughout into them, coat in fiberglass, and forget about it. I'm still living aboard so making this project even bigger would be too much. Hopefully not living on it for more than 1 more year and after that, so long! But I said that a year ago, and 2 years ago, so...
