Don Guillette
John Scharer: I’m going to keep this very simple so I don’t confuse myself. The chord line is the horizontal luff to leach measurement of your sail. In other words, the foot of the sail. That measurement never changes no matter what sail trim adjustments you make. If it did, you could not make the proper adjustment for a given point of sail and wind condition. Assume the wind conditions called for 50% draft position and 20% draft depth (belly). Without knowing the chord you could not make that adjustment. Draft depth (belly) and draft position work together and to get both positions where you want them you have to use all the sail trim controls for both those items. Please refer to the Quick Reference that came with your Sail Trim Chart. Note that the sail trim controls for draft position are the boom vang, Cunningham, mainsheet, mast bend and outhaul. The sail trim controls for draft depth are mast bend and outhaul. So, you can see in your question, that when you adjust the outhaul you are primarily adjusting the draft depth (belly) but you are also adjusting the draft position.An easy way to record the optimum setting for each point of sail and wind condition on your boat is to do just that – mess with the settings and record the best ones.Draft depth, draft position, twist and angle of attack (The 4 Elements Of sail Trim) are hard to understand at first. That is why I say in my book, do not proceed past the chapter that explains those elements until you fully understand them as nothing that follows will make any sense. Once you understand those concepts, the flood lights come on and you know more about sail trim than 75% of the sailors worldwide!! I hope I’ve answered your question. If not, ask again and I’ll give it another go.
