Draft Depth
273
RAPTOR Hotfoot 20 Ghost Lake
One of you trim gurus must know the answer to this one. What should the maximum draft depth be? I have a new loose footed main and have just installed a new outhaul system so I'm interested in the optimum trim.I've been told the maximum draft depth should be 6" but it doesn't make sense to me that it would be the same for all sails.I would guess it would be a percentage of the foot length just like draft position is always given as a percentage of the boom length. Anyone know?
Ross
Jun 15, 2004
14,693
It depends upon the wind conditions.
Light winds can use a fuller sail.
Jul 8, 2004
361
S2 9.1 chelsea ny
correct to a point
Ross is correct that in lighter air you want more draft in the main. But from under, say 5-7kts. of wind, you want a flatter main to start out with (until you get some apparant wind going) as in the lightest of air, with a full draft, the air will not stay attached to the sail. This unless you turn on the iron genny...in which case you'll have a draft beer instead.
Other Catalina 30 Tucson, AZ
Ken: Any listers who have my book and chart could answer this question by going to page 11 in the book and page 1 in the chart. Draft depth is described as a percentage of the sails (main or jib)width or depth at its widest point, which is the deepest part of the sail. Using a percentage may appear complicated but it works. Say your chord line is 10' long and the distance from the chord line to the deepest part of the sail is 1' then your draft depth would be stated at 10%. If the distance was 3' then the draft depth would be described as 30%. Lets say you don't want to mess with the chord line, which is ever changing, what can you use to get into the ball park? The answer is use the length of the foot of the sail. Ken, using the above example of 10'chord or boom length, 6" of draft depth would equate to a draft depth depth of 5%. If you were sailing in very light wind then that position would be right. If they actually ment to tell you that 6'(60%) would be the max draft depth they would be off by about 30%!! In general, 25% to 30% is the max you would ever need. Here's how draft depth works. In very light air you want the flatest sail you can get because the wind does not have enough power to get around the sail and it stalls. That is why sailors who put belly into their sails don't go anywhere in very light air. They think bellying out the sail will develop speed and it does not happen. Next time your out sailing try it and see what happens. As the wind starts to pipe up you gradually want to induce more belly (equates to more power) into the sail. At about 10 knots you want to start reducing the power of the sail by starting to flatten it. After about 15 knots or so you want to really flatten the sail to reduce power. So you go from flat to belly and then back to flat. That's how it works. The outhaul is not the only draft depth control. Mast bend is the other. I don't know what kind of a boat you have and you may not be able to bend the mast. You may only be able to rake it back, which has nothing to do with draft depth. So know you know how to work the outhaul and all you have to do is experiment to get the proper setting for each point of sail and wind condition. The problem is that there are 3 other elements that you have to mess with in addition to draft depth and they are draft position, twist and angle of attack. They have their settings for each point of sail and wind condition. You can't just mess with draft depth and expect to get 100% efficiency from your sails. Those of us that remember cars that had carbs with adjustable jets are aware of how important it was to adjust ALL the jets. Younger folks don't know about that. In other words, all the sail trim controls for the main and jib are there for a reason and you have to use all of them to get top performance out of your boat. Hope this helps. If you have any other questions just fire away.
May 11, 2004
273
Thanks
Thanks Don - that's exactly the information I was looking for. I'd like to add I enjoy following your forum and I think I'm a much better sailor because of you. I know it gets frustrating from time to time but there's a lot of us that appreciate your efforts and the comments of others that contribute to the threads.
