Asymmetrical chute?
An asymmetrical chute is really easy to handle if you have a snuffer. No pole, no worries. It really is a nice solution for downwind sailing. You can find them on E-bay (used, generally, so be careful) pretty cheap. Or, buy a new one for around $1500, including a snuffer and turtle bag.A whisker pole is also a good solution, especially if you have a fairly large genoa. Sailing 'wing and wing' worked fairly well on my boat using that technique. But you still have the same issues with the main, either way. I certainly agree with Bill's suggestion to rig a preventer, or a 'boom-brake' to the main when sailing downwind. Moreover, I agree with you, insofar as I think that a broad reach can be preferable to a dead run, all things considered. Depending upon the wind and your sail wardrobe, jibing from broad reach to broad reach can actually be faster going from point A to point B than if you are sailing entirely 'before the wind.' Personally, I prefer to keep the main off of the shrouds, if I can, and agree wholeheartedly with Warren in that regard. Chafe, per se, might not be a problem, but I developed vertical stains on my old main that were caused by years of contact with the shrouds.Good luck. Have fun- Rick
