Dometic AC needs capacitor
kbgunn
Sep 19, 2017
231
2005 Hunter 33 Lake Lewisville, TX
I have a Dometic MarineAir 16K AC model VTD16K-HV. It has a dual start capacitor for the compressor and run capacitor for the fan. The value is non-standard. 30uf start + 16 uf run. I can find an exact replacement looking at HVAC supply houses. There isn't room in the enclosure to replace with two capacitors of the exact value. Anyone know a source of supply?
The Aerovox part number Z24S37... returns nothing. The Dometic part number is the 4040039, but i don't find any. Pic below.
Feb 26, 2009
716
Oday 30 Anchor Yacht Club, Bristol PA
a capacitor be mounted almost anywhere that it will fit, just extend the wires. Do you know it's actually bad? (Shorted, open, leaking, swelling)
Ratings can be plus or minus 10% if memory serves,. This would also be a good time to install a hard start kit which is nothing more than a ceramic resistor although the larger ones have a start capacitor,
Oct 29, 2005
2,366
My search tells me the uF (MFD, micro Farad) can be up to +20% and the voltage rating can be equal to stock or higher.
Ken Y
Feb 26, 2009
716
Ken Y
That reminds me back in the day when I had a thriving business we would pull the capacitors out of units coming out for replacementO often times when out on service calls they'd have some in the truck and say; "this one looks like it'll work" :) there was a time when capacitors had pcbs in them.. yeah I'm that old lol
Tater
Oct 26, 2021
198
Hunter 170 Lake Logan Martin AL
...... :) there was a time when capacitors had pcbs in them.. yeah I'm that old lol
My dad acquired a salvage pole transformer for a homemade welder. I played with the oil. I played with mercury too. I likely chewed on lead painted baby bed rails. I am that old too.
Tater
Oct 26, 2021
198
Crusty,
I noticed you location. In October, my First Mate and I did a lighthouse tour from Maine to the Outer Banks. We stopped at Fort Monroe for Old Fort Comfort. While she got her photos, I watched the sailboats from the fishing pier. That trip was the inspiration to return to sailing after many years.
Aug 19, 2021
511
Hunter 280 White House Cove Marina
Crusty,
Funny thing is, I drive across the Hampton Roads Bridge Tunnel almost everyday. The view of the Old Point Comfort Marina and the sailboats cruising up and down the shipping channel and in the Chesapeake Bay reminded me daily that I promised myself that someday I would learn to sail. I love the views looking out from the Deadrise restaurant these days.
Likes: Ward H
kbgunn
Sep 19, 2017
231
Hey DeniseO30
I put this issue aside during the cold months and now the warm months are fast approaching! I bought a meter and the start + run cap checks out good. But the compressor isn't starting.
Can you give me any other troubleshooting tips? What voltage at the compressor? Resistance of the windings? How do I know the compressor is bad or if it's something else?
Thanks!
Feb 26, 2009
716
You might go on YouTube and look up how to "Ohm a compressor" but if it doesn't start, hums and clicks hums and clicks and still doesn't start, it's probably stuck (locked rotor) A hard start kit s
May start it what happens the liquid refrigerant forms droplets in the oil and keeps the Pistons from moving once it gets turned over there usually okay until whenever it happens again larger units have what is called a crankcase heater I keeps the compressor warm
kbgunn
Sep 19, 2017
231
I have narrowed it down to the compressor relay on the control board. Compressor was getting 0v when the t-stat was calling for cooling. Water pump and fan run as expected. Replacement board is in the neighborhood of $300-400. Anyone ever replaced the relay on the circuit board? Or used an external relay soldered to the board? I'm thinking it's the big 40A/240VAC on in the middle and not one of the 20A/120V relays on the sides.
Mar 6, 2008
1,420
Yes, external relay can be used. If you are confident with the impedance of the coil and contact rating and voltage required to pull in the contacts you can wire it in. You have nothing to loose since you may have to replace the board in the worst case. Contact digi-key.com and contact their techs for suitable replacement. They may have the exact replacement.
Feb 26, 2009
716
Can't quite tell is the relay fried on the outside looks like it may be. I would not go out and buy circuit board until you're sure the compressor is good or bad, most technicians can test or even run the compressor without the circuit board why spend good money for bad, that amount of money is easily 25 to 30% that could go towards a new unit.
Jun 21, 2004
3,055
Beneteau 343 Slidell, LA
Yes; however, my relay was on a separate board with jumpers to attach to main board. It was simple to replace and relatively inexpensive.
You might want to check out Flight Systems, Inc. They will trouble shoot for a nominal fee & provide an estimate. There is also a trouble shooting guide on their site.
www.flightsystems.com
Tater
Oct 26, 2021
198
I am certified and at one time had a refrigeration contractors license. I have done the work in an institutional setting. I also have 40 years in electronics. The relay is likely just the tip of the burg. Relays don't just fail. The compressor is likely locked, a very common issue with small units. Denise has it right. Don't spend money unless you know for certain what the problem is.
I would replace the unit if it is 5 years old. If you can find a replacement that is not for a "BOAT" that can save money. At last resort a pro may be needed.
Dec 2, 2003
766
Hunter 260 winnipeg, Manitoba
Have you removed the board from its mount and had a look at the back side? Often when components go bad you will be able to see evidence of their failure on the back of the circuit board. - burn marks, cracked, melted or failed solder, missing component pins etc. In some cases the damage on the board from the failure will be such that the board itself can’t be reliably repaired.
All of that being said if it is a single relay that has failed they can usually be fairly easily replaced.
With board out You should be able to test the suspect relay with a 5v power source and check that the circuit closes properly.
Feb 26, 2009
716
Im 73 I was born in the contracting, most of all of it was in hvacr
Just keep in mind! most machines in the past 20 years even, are designed as throwaway technology that's why so many use a circuit board with all the controls on it.
Make sure the compressor is good! only three terminals start common run and the start capacitor with ceramic resistor. it's a very simple hook up once you know how, if you haven't thought of it you could probably pull the unit out of your boat and take it to somebody, its not much bigger or heavier than window unit.
