Domestic Water Leaks
119
Beneteau Oceanus 321 Carters Pt.
Just some information.We have a Beneteau 321 (1997) second owner
We were on a cruse last week when domestic water pump started to cycle when not in use.Started looking for a leak.Found leak under galley sink
where hot/cold and water line for swim platform were tie wraped together.
Cold water line had chafed through .
Water lines in our boat are PEX 1/2 inch lines with compression clamps.Cut out defective section of line and inserted a section of new PEX with compression couplings .
Jul 8, 2005
522
Jeanneau 389 Grosse Pointe Farms, MI
Great to know. I will have to look under there this weekend and see what they look like.
We have had a small leak into the electrical panel (right side) which must be the windows. I have tried sealing the windows from the inside and even put clear sealant around the outside. Always seems to help but never lasts. One of these days, I will get the courage to just replace the entire window, but I have not figured out yet how to get the window off after the unbolt the frame. Have you done that?
