Dome Light Bulbs Hunter 30 1989
BarNEY Flybb
Looking for bulb number for Hunter 30 '89 cabin dome lights. These are [probably GEM Product lights but GEM cannot furnish bulbs. The originals are 10 watt festoon types. Also looking for advice on securing the two forward bolts on base of Edson cockpit wheel column. Can you drill thru to the aft sleeping compartment to secure these bolts with nuts? Will this somehow compromise the cabin? Currently the bolts (screws) are 1) inaccessible to fasten nuts 2)appear to be anchored in some kind of plastic glue 3)are flat head recessed screw types in the Edson holes designed for hex-head bolts.
Jul 17, 2005
586
Hunter 37.5 Bainbridge Island - West of Seattle
That plastic glue
If that plastic glue is white, it is probably 3M 5200 marine adhesive. Once you put it on a fitting, you will probably never be able take it off. At least not without a lot of hard elbow grease.
Ron
Edson Bolts
We had the same problem, got sainless steel bolts .5 in. loger, problem solved. It appears that Hunter used bolts that where a tad short on the forward two. Hope this works as well for you as it did for me. Ron
Sherry
Jun 1, 2005
212
Hunter 30 Pickwick Lake, TN River
dome light bulbs
My 1992 owner's manual says: #1572 and Wagner #S8-1141 Hope this helps. Sherry
Likes: R gibbs
