Does water entering chain locker via chain pipe drain to bilge?
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi all.
I am still obsessing about ingress of rain water (I'm pretty sure that it is rain water though as I'm on a fresh water lake it is hard to be certain).
I have maybe half an inch of water in the bilge. Obviously not a problem but I want to figure out where it is coming from.
I noticed at weekend that there is wetness under the batteries in the battery sub bilge forward of main bilge.
That could be from the locker under starboard saloon berth but I have checked (I think) all possible sources (sink pump etc).
It occurred to me that water draining from chain locker has to go somewhere - is there a conduit running back to the battery bilge?
There seems to be a slot in the forward end of the battery sub bilge like that on the starboard side of the sub bilge??
Suggestions very welcome..
John V1447 Breakaway
Feb 13, 2010
528
Yes The chain locker does drain into the bilge. I can't imagine that
enough water could go down the Hawser pipe to put that much water in
the builge except over a very long period of time??? I guess it's
possible?? doug
On 08/25/2014 02:36 PM,
John.Kinsella@... [AlbinVega] wrote:
Aug 3, 2005
66
Check that your foot pumps aren't leaking. I had a leak that left me scratching my head until I replaced a corroded pump.
Tom
Aug 23, 2014
25
Speaking of foot pumps, what is proper procedure when they fail? Is my only option replacement, or are rebuild kits available?Jacob
Nov 8, 2001
1,818
Check the seal between the cockpit sole and frame,
check foot pumps in toilet and galley, check gap between
washboards.
Does it happen when it is heavy rain? If so I
expect cokpit sole and sal
Steve B
[AlbinVega]
Sent: Monday, August 25, 2014 7:46 PM
To: AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] Does water entering chain locker via chain
Yes The chain locker does drain into the bilge. I can't imagine that enough
water could go down the Hawser pipe to put that much water in the builge except
over a very long period of time??? I guess it's possible??
doug
On 08/25/2014 02:36 PM, John.Kinsella@... [AlbinVega]
wrote:
Feb 13, 2010
528
Also check the hoses from the channels that go around the wood seat
covers in the cockpit I had one that was stopped up where they run
out onto the cockpit floor and a hose was cracked at the fitting and
leaking.. Doug
On 08/25/2014 03:41 PM,
'steve@...' steve@... [AlbinVega] wrote:
Oct 19, 2019
921
Thanks Doug, Steve and all.
Doug: How does water flow from chain locker? Is there a conduit? Some kind of tube? Where is it?!!! :)
Steve: water from cockpit isn't going to get under batteries? I know that water can get from under sink to under starboard saloon berth and from there to battery bilge but I'm pretty sure that's not happening..
And I've gone to some trouble to seal under cockpit sole.
But I've been wrong before... :-(John
Nov 8, 2001
1,818
Cheaper to replace pumps, availabe at reasonable
price nowaday
Steve B
wisdomracing@... [AlbinVega]
Sent: Monday, August 25, 2014 8:16 PM
Jacob
On Mon, Aug 25, 2014 at 11:48 AM, Tom Rutter tom.rutter@... [AlbinVega] AlbinVega@yahoogroups.com wrote:
Nov 8, 2001
1,818
Hi John
Sounds like pump in The Heads. Sounds like water
coming from forward if under batteries. Perhaps pipes from bottom of water tank
where the pipes come out (two of them).
Cheers
Steve B
[AlbinVega]
Sent: Monday, August 25, 2014 9:07 PM
Thanks Doug, Steve and all.Doug: How does
it?!!! :)Steve: water from cockpit isn't going to get under batteries?
from there to battery bilge but I'm pretty sure that's not happening..And
I've gone to some trouble to seal under cockpit sole.But I've been wrong
before... :-(John
Feb 5, 2002
37
I had a somewhat curious leak on my series I, the fill hose at the water
tank had kinked the tank at the fitting and there was a leak.
Ric Eiserling #935
Feb 13, 2010
528
It just flows along the "v" inside the bottom of the hull and under
the cabin sole back to the battery compartments and into the keel.
In the spring when I fill te water tank after it is full I keep
running water and it goes down into the chain locker and washes any
mud that may be in there back into the keel. Then I wash out the
keel with a water hose while pumping the dirty water overboard. I
noticed my boat smelling bad and someone suggested I do that. Works
a charm and keeps the bilge sweet.
Doug
On 08/25/2014 04:07 PM, John.Kinsella John.Kinsella@...
[AlbinVega] wrote:
Feb 13, 2010
528
Your right of course mine was running under the engine and I think
it was filling the engine drip pan but don't remember for sure.
Which was a mess. Doug
On 08/25/2014 07:35 PM, ric@...
[AlbinVega] wrote:
Nov 8, 2001
1,818
Hi Marcin
I picked up a few pumps from the local Chandelery
very cheaply (£25 each). That was a few years ag though.
As you say the Mark I kits are not
available.
Cheers
Steve B
rom: Marcin Palacz
palacz@... [AlbinVega]
Sent: Monday, August 25, 2014 10:32 PM
On 25/08/14 23:17, \'steve@...\' steve@... [AlbinVega]
wrote:
Oct 19, 2019
921
Hi Doug.
I'm confused!
The inner underwater hull is *below* the battery compartment? So how does water get to battery compartment from chain locker?
John V1447 BreakawayOn 26/08/14 00:36, Douglas Pollard
dougpol2@... [AlbinVega] wrote:
Aug 29, 2011
103
John, I think Doug is suggesting water drains from the chain locker, down a V channel down the centre line of the boat (where the keelson would be on a wooden boat) from the bow, under the sole in the head compartment, and under the forward part of the cabin sole, and drains into the battery compartment, which you called "the sub bilge forward of the main bilge", and from there into the bilge. I had not realised there was this double skin, as it were. Presumably you could check by looking at the forward end of the battery compartment, under the cabin sole, to see if there is such a channel draining in. I don't remember it in my Mk 2. I agree with others who have said it seems unlikely to be from the chain locker, unless you leave the chain pipe uncovered and you have had monsoon quantities of rain recently. But the answer to your original question (the title if the thread) must be yes, not just for rain water but also the water that drips from the wet chain when you weigh anchor, and water from seas breaking over the bow on a beat. We don't have the through hull drains at the base of the chain lockers that some larger boats have, and Per Brohall could not have expected evaporation to keep the locker dry. Water cannot drain properly across the cabin sole, because of the lip between cabin and head compartment. So there must be some channel to the bilge such as Doug describes, even if it doesn't drain into battery compartment.The other obvious suspects have been well covered in this thread - water tank and hoses, head and galley sea cocks and hoses. Could it have anything to do with the water ingress which damaged the wood laminate in your main bulkhead? Could it be from a leaking though deck fitting (mast cables, heater chimney) or a damaged chain plate or stanchion fitting? Every time it rains, we have a drip from one of the dorade vents which someone fitted above the cabin seats/berths. Have stripped the vent down twice and still not found the source of the drip. Let us know when you solve the problem. Good luck. Tom
Oct 30, 2019
1,459
I once had all my water leak our when the hose to the head sink came off. That was before I took out the head sink and plugged that opening at the tank. Nicholas H. Walsh Admiralty and maritime law; Commercial law Nicholas H. Walsh P.A.120 Exchange StreetP.O. Box 7206Portland Maine 04112-7206Phone: 207/772-2191Fax: 207/774-3940 This email is from a law firm and may contain information that is privileged and confidential. If you suspect you received it in error, please delete the email and contact us. From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] Sent: Monday, August 25, 2014 5:21 PMTo: AlbinVega@yahoogroups.comSubject: Re: [AlbinVega] Does water entering chain locker via chain pipe drain to bilge? Hi John Sounds like pump in The Heads. Sounds like water coming from forward if under batteries. Perhaps pipes from bottom of water tank where the pipes come out (two of them). Cheers Steve B From: John.Kinsella John.Kinsella@... [AlbinVega] Sent: Monday, August 25, 2014 9:07 PMTo: AlbinVega@yahoogroups.com Subject: Re: [AlbinVega] Does water entering chain locker via chain pipe drain to bilge? Thanks Doug, Steve and all.Doug: How does water flow from chain locker? Is there a conduit? Some kind of tube? Where is it?!!! :)Steve: water from cockpit isn't going to get under batteries? I know that water can get from under sink to under starboard saloon berth and from there to battery bilge but I'm pretty sure that's not happening..And I've gone to some trouble to seal under cockpit sole.But I've been wrong before... :-(John
Oct 19, 2019
921
Thanks Tom & all.
As you suggest,
I'll report back when I figure it out...
JohnOn 26/08/14 11:33, Tom Fenton
tjhfenton@... [AlbinVega] wrote:
