Does a Javelin 14 rudder float
aschum
Aug 11, 2013
1
Oday 14 Sodus Bay
Tip over yesterday in heavy wind and lost rudder. I think it went to the bottom. Anyone know for sure. Also do you know where I can get a replacement for a 1974 o'day Javelin
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Your rudder is probably laying on the bottom. I don't think any of these rudder blades float. I'm sure Rudy has these rudders.
http://www.drmarine.com/
There is one thing that you should do when you get your new rudder. Install a rudder lock on your transom so that doesn't happen again.
My O'Day 222 has a small hole near the tip of the upper pintal on the rudder head to receive a wire type locking cotter clip. This clip works almost like a safety pin. You just stick it in the small pintal hole which protrudes a and 1/8" past the bottom of the top gudgeon and locks it in place.
Jun 2, 2004
1,957
Oday Day Sailer Wareham, MA
The original rudder on the 1982 and older Javelins (as well as the Day Sailer, exact same rudder) will not float, the newer ones (about 1983-89) might float, since O'DAY changed to a new design that had an aluminum top and wood blade for those years. The aluminum might be too heavy for the wood to support?
As Joe has said, Rudy at D&R Marine has the original rudder and most likely the newer one, not cheap! Also, you will need to change the mounting hardware if you switch to the newer version (original wil lfit with out mods).
Along with the suggestion that Joe had for a retaining pin (rudders from D&R have that hole already fitted and include pin.), I'd suggest a short lanyard that attaches to the rudder and is just long enough to allow the rudder to be taken on/off while the other end of the lanyard is attached to the boat. I had one of those on my old Widgeon and it was very handy!
Finally, the best advice to avoid repeating that capsize would be to ALWAYS sail with the mainsheet in your hand, use the camcleat to hold the tension, but hold the sheet in hand ALWAYS. That way, if a gust hits, you can release the mainsheet easily to spill the wind and prevent a capsize. I'ver used that technique successfully on my DS II for 17 years and on my Widgeon for 7 years before that.
