Documentation numbers
May 10, 2004
254
Hunter MH 37 Manitowoc, WI
This is the first time I will have a documented boat. How did you guys install your numbers. I've found some laser-etched stainless plates on the Web. I'm a little concerned about routing numbers on a laminate bulkhead.
Nov 8, 2010
11,386
Sand a portion of your exposed hull or liner, Paint on the numbers (stencil if you want to be neat), and brush over with some resin when done. That's pretty permanent.
Apr 11, 2010
998
Hunter 38 Whitehall MI
Go to hardware and buy stick on numbers of the required size. Stick them to the hull - I put mine behind the settee cushion.
Get some west systems epoxy and mix it up and paint over the numbers.
Permanently attached, inexpensive and nice looking.
Feb 16, 2012
199
Hunter 45 CC Alamitos Bay, Long Beach
Take a look at this website. We ordered our USCG Documentation Plaque from them. Very high quality workmanship.
"American Wood Sign Company"
Phone: (660) 748-4829
http://www.americanwoodsign.com
Jeff
Mar 26, 2011
4,068
Corsair F-24 MK I Deale, MD
a. It should be a non-removable sign. Burned into a beam, or as other suggest, laminated in.
b. It does NOT have to be in plain view. Inside a locker is just fine.
Jun 11, 2011
1,243
Hunter 41 Lewes
Go to hardware and buy stick on numbers of the required size. Stick them to the hull - I put mine behind the settee cushion. Get some west systems epoxy and mix it up and paint over the numbers. Permanently attached, inexpensive and nice looking.
This is how I did mine, it is fast and easy. Inside the port lazarette.
Jul 1, 2014
264
Hunter 34 Seattle
On my boat the PO stenciled the numbers (paint) on a beam member in the bilge and glassed over it.
