AC DC Basics
BillAC and DC are two separate things.The AC outlets (120 volts, like at home) will only run from shorepower (unless you have an inverter). There should be a separate AC power switch on your panel. It needs to be ON to use the AC outlets. AC power on board is usually for only two things: AC outlets and the water heater.The DC side (12 volts) is from your batteries, using the 1-2-Both switch. This runs your lights, bilge pump, engine starter, etc. It has absolutely NOTHING to do with the AC side. If the 1-2-Both switch is OFF, nothing on the boat will run, even if you're connected to shorepower, since the boat systems (except the AC outlets) run on DC power from the batteries. The 1-2-Both switch IS the DC power switch.Your battery charger works from the AC side, and simply converts 120 volt power into 12 volt power to charge your batteries. The charger is wired directly to the batteries, it shouldn't go through the 1-2-Both switch, because the switch is only used to take power OUT of the batteries. The charger is usually wired directly to the incoming AC power, however, it may be switched from the main AC power switch, so you need to check: if it runs when you plug into shorepower with the AC switch off, it's directly connected; if you need to turn the AC switch on to power up the charger, it goes through the AC power switch on the panel.Since you're new to this, please do yourself a favor (intellectually and safety-wise) and buy and read Calder's Boatowner's Manual. It will answer all the questions you're going to have, and save you a lot of time typing questions to this forum.You will also have to look at your boat and follow all the wires so that YOU understand what is there on your boat. All we can do is help to point you in the right direction.Good luck.
