I've been doing this to save time rigging the boat but lately I'm finding that it makes handling the boom a pain so I'm wondering what others do. If you remove your main, can you share your technique?
Exactly the same method here. Except I have no topping lift, just a pigtail on the backstay.I stow my boom with the main and sail cover on. I leave the topping lift attached to the aft end of the boom, but disconnect everything else. When I disconnect the forward end of the boom from the mast, I can just walk that end of the boom back to the cockpit, and then down into the cabin below. Then finally, I disconnect the topping lift. I don't have to carry the full weight of the boom and sail that way. Not that it's heavy on my boat.
My Mac was so much simpler to manage.I tried this once. It was the dumbest thing I ever did. Perhaps because it's 10' long.
This works for me to. If you're alone, I've found that you can "manipulate" the forestay (assuming jib on furler) to the left and right of the mast to find a sweet spot. A bit more of a hassle but can work none-the-less.We are dealing with boats trailer often. @CrispyCringle
If your better half or anyone else is with you, have that person facing you with one hand on port spreader and other hand on starboard.
Yep! That is how you do it.I stow my boom with the main and sail cover on. I leave the topping lift attached to the aft end of the boom, but disconnect everything else. When I disconnect the forward end of the boom from the mast, I can just walk that end of the boom back to the cockpit, and then down into the cabin below. Then finally, I disconnect the topping lift. I don't have to carry the full weight of the boom and sail that way. Not that it's heavy on my boat.
