Do I really need it?
795
Hunter 33.5 Elbow, Saskatchwen, Can.
I've always thought that there's no such thing as a stupid question. With that in mind I have one. Maybe the answer is obvious to you.
Anyway if I have a traveler do I need a boomvang? I haven't taken the vang off and gone sailing to try it. But it seems to be just along for the ride.
Thanks
Don
26209
470
Hunter Legend 35 Kingston
The vang is very important. Among other things, going downwind, with the boom all the way out, the traveler will not help keep the boom from rising up, but the vang will. Critical if the wind is strong.
You can do without a traveler much more readily than doing without a vang.
Chris
Sep 4, 2007
795
It doesn't show up well in the picture I added. But the Vang never seems to need adjustment. I tend to do all the adjustments with the traveler. I tried adjusting the vang and it does seem to relieve some of the pressure on the traveler. But not enough to notice. Can anyone suggest a book that I could read that might help? Maybe a book on sail-trimming?
Thanks
Don
Creola
Sep 16, 2009
20
Hunter 31 Grand Rivers, KY
Don, I adjust my traveller constantly in higher winds or gusty winds to ease some power out of the main without altering the sail shape. Most adjustment is done when healing beyond 30 degrees and losing efficiency of hull.
As Chris says above, the vang is important to keep boom from rising up in downwind run.
One of the best books I have found on sail trim for cruisers is titled, "SAILPOWER Trim and Techniques for Cruising Sailors", by Peter Nielsen. Runs around $35 and can be found online or ordered through big box book stores.
G
Guest
Sail Trim
Hi Don, you have come to the right place, but do need a different venue. Try the Sail Trim Forum on this site that is chaired by Don Guillette. He also published some sail trim manuals that I highly recommend you acquire, study and apply.
Terry Cox
