Do I need to replace these lights?
Mar 26, 2011
3,717
Corsair F-24 MK I Deale, MD
I'm puzzled, since I have had several of that model, older than that, and they never got like that. Weathered, but not bubbled up. I'm suspecting a bad batch of plastic.
But it would have been time anyway. Yes, LED. It's way more economical to reduce consumption than to generate and store more.
Ward H
Nov 7, 2011
3,786
That was my thinking, weathered yes, not bubbled up. The bad batch of plastic would explain.
Ward H
Nov 7, 2011
3,786
Rich didn't quite believe me that you flip the switch twice to get tri-color, then again to get SOS. He said "is it really that smart?" A little smarter than Rich, I'm guessing. :biggrin:
LOL
Nov 8, 2010
11,386
The tri-function anchor light is really a cool product. Now that I have explained to Rich how it works, he shouldn't give you a hard time about it. First he told me "your anchor light doesn't work" then he said I would need to run more wires up the mast for it. Just remember that the anchor light has a photo cell that over-rides the switch if you test it out in daylight. Rich didn't quite believe me that you flip the switch twice to get tri-color, then again to get SOS. He said "is it really that smart?" A little smarter than Rich, I'm guessing. :biggrin:
If you don’t want that (light sensor) function, you have to totally blank it out. I used black Enamel paint. Tape didn’t work well enough. Needed to do it because the white light is part of my 3 color nav display.
Ward H
Nov 7, 2011
3,786
Nice trick. I made note of that on my project list as I like to check my lights before I need them which means I need to check them in the daylight.
Was that MarineBeam's suggestion?
Nov 8, 2010
11,386
I didn’t ask them. But we used it in the electronics business to blank out parts. It’s UV and heat resistant, and totally opaque.
Aug 1, 2011
3,972
A recently discovered alternative is liquid electrical tape. While it's not for everything, it seems to be more forgiving in outdoor applications than enamel, and it's more pliable if that matters.
