I have an old Cat 27 and it has no winch for the Jib sail. The problem is when I pull up the jib I run out of line and it changes to steel cable, I end up wrapping the cable around the cleat to hold the sail in place I am thinking a jib winch on the mast could be the simple solution. Basically to wrap the cable around, so I can tie the line to the cleat. Is there a less expensive way to solve this. Can any of you recomend a cheap winch that will do the job, as it would basically be serving as a drum
Thanks
Buzz
Thanks
Buzz
