Hi Peggy,I purchased a "new to me" 33'Cal and ripped out the entire head system and replaced it with new hoses, new elec. head, holding tank, and elec. overboard discharge pump. The outlet from the holding tank goes to the diverter valve where one side of that goes to the deck pumpout fitting and the other side goes to the elec. dicharge pump. After the pump, which sits at about the waterline, the hose goes upward above the waterline and then down to the throughhull, well below the waterline. The pump has two duckbill valves in it. The head also has another duckbill valve. Do I need a vented loop between the discharge pump and the throughhull?P.S. I replaced the old hose with the Shields hose and then saw your recommendation to use the SeaLand Odorsafe hose, so I did that too. That stuff is a bit of a wrestling match to put in.Thanks Much,Chuck
