Do I need a macerator?
Apr 24, 2006
868
Aloha 32 Toronto, Lake Ontario
Plumbing in the offshore holding tank emptying system.
The bottom of the holding tank is a foot above the thruhull and has it's pumpout fitting at the bottom (no dip tube).
Will gravity be sufficient or do I need a macerator pump?
Thank you ,
Chris
Is the bottom of the tank above the waterline at all angles of heel? If not it will only drain to the waterline or when heeled water will enter the tank.
Apr 24, 2006
868
Oops. I'm guilty of not searching before posting lol .
Found the recent post explaining "gravity dumping".
Looks like I just need to confirm my holding tank is above the waterline and not just above the thruhull .
Chris
Apr 24, 2006
868
But I do have one question. I need to also keep the deck pumpout .
Do I really need a Y valve in the tank discharge or simply T it to both the thruhull valve and deck fitting? Seems to me I'd just have to open the thruhull valve to enable dumping and when closed the deck fitting is enabled?
Chris
868
Lol. Must be too early. I found the answer further down in the thread I mentioned earlier.
I do have Peggy's book but it's on the boat and I'm not. Great book.
Dec 2, 1997
9,011
- - LIttle Rock
Since you're setting the system up to dump via gravity, a tee or a wye will be ok. If there's to be a overboard discharge pump, you'd want a y-valve so you could cut off the flow of waste to the pump when it needs work. 'Cuz nobody ever discovers that the pump won't work when a tank is empty!
--Peggie
