If it is not too late consider this added expense
You state that you are getting ready to buy a new boat. I hope that it is not too late for you to consider some options.I have a catalina 387 with furling set up on both the head sail and the main. The main is an in mast roller furling. Had I to do it over again, I would have gone with the in boom roller furling system which was in its' infancy at the time I got my boat. Maybe a little more expense, however, with this you would be able to have a main sail with battens. I have seen and perhaps you might want to research this a little bit, main sails with battens in them that run in a sort of verticle orientation to be used with the in mast furling system. For me, furling systems were mandatory since I am older and 99% of the time am single handing the boat. At near 40 foot, it is just too much for me to be up on the bow hoisting a 155% genoa alone in 15 to 30 knots of wind. The boat came as was and the deal was too good to pass up, so I had just had to do with what was present and since I got it to cruise with then the full efficiencies that I miss out on are something that I am willing to do with out. I will accept the loss of 1 to 2 knots per hours since if I were in a hurry I would have a power boat. I did have my sail maker add some tell tales to the leach of the main sail that help out substantially. Observation of the flow of the air coming off the main is a real true indicator, more so than at the luff since the boom disrupts the air flow in that locale, where as on the head sail you will find the opposite to be more true. I also had some additional tell tales added to the head so that when I have it furled into say about a 100% in contrast with 155% I can still observe the quality of the air flow. Also, to reduce turbulence at the leading edge of the head I had the sail maker add three luff cords. They help the sail furl up much tighter to eliminate the bulge that forms there and this reduces the turbulent air flow.Also, I strongly encourage you to get a copy of Don Guillette's [(sp) sorry Don] book on sail trim. You should read his book carefully again and again; he will explain how you can use many other factors in addition to the battens to help you get optimal sail trim. He in fact discusses trim of the head sail without the battens and explains how you can make up for their absence, which I have found that I can apply to my main with the lack of battens.Good Luck, Tom
