Derek Rowell
Never done it before but I'm ready to go - bought the Dr. Shrink kit and all the goodies - I've watched his new video CD a hundred times. He covers a small sailboat with the mast up. The technique is to use two sections of film (fore and aft) overlapped at the mast and heat-sealed together. Looks real simple when he does it but the problem is that he could reach over the side of the boat all the way to to the mast in order to heat-seal the fore and aft sections. On a bigger boat you can't do that, and somehow I will have to work with the heat gun from the mast outwards on each side while I am on deck. As I see it I will lay out the aft film first and tape around the mast, cutting in for the shrouds. Then I'll do the forward section, but roll (scrunch) it back up to within 2-3ft of the mast, so that I can work on the join from the fore-deck. I'll then tape and heat-seal the two sections around the shrouds, and then unroll the film to cut and fit around the forestay and bow.It was suggested on the CSBB board that I use a single sheet, and split it along the centerline from the mast forward, then overlap, tape and seal the centerline forward of the mast. Somehow that seems to be not as strong, and the effects of the seam coming apart along the heat-seal would be much more severe.Any other suggestions? Now if this New England weather would just cooperate ;D ...
