Any dive, with compressed air, is serious
As soon as you submerge using compressed air you are adding air volume to your lungs to equalize the effects of the added pressure on your body in the water. Air, at sea level, weighs 14.7 pounds per square inch (psi). Water weighs more than this, though. Each one-inch column that's one foot deep will weigh 0.445 pounds. So if you're right at sea level, the pressure will be 14.7 psi. And for every foot you go underwater, you add another 0.445 pounds. So at one foot deep, the pressure would be 14.7 psi + 0.445 psi = 15.145 psi. And at two feet deep it would be 14.7 psi + 2*(0.445 psi) = 15.59 psi, etc. In order to get to the bottom, and under, most keels, a diver will submerge 8-9 feet. The pressure there is approaching 19 psi. If your compressor is compensating, your lungs are filling with over a third more air than they would take in at sea level. At 8-9 feet below the surface, the lungs are fine, if this pressure is maintained up to sea level, your lungs will be ~35% over capacity. This is the root cause of embolisms. It is imperative that your lungs purge all excess air as the surrounding [water] pressure is reduced (as a diver ascends for example). This is accomplished by exhaling as you ascend. One of the very first rules a diving instructor will share with a student is the importance of breathing: on the way up as well as down. Often when a person finds their air supply has failed, their first reaction is to hold their breath. If your last breath was at sea level, regardless of how deep you were able to descend, holding your breath during the ascension is fine because no incremental air was introduced into the lungs. If you were using a breathing aid, the result will be progressively worst the further you have to ascend.Exhaling on the way up from a compressed air aided dive is just one of many rules one should understand and practice before venturing under the water with more than a snorkel and mask. Lessons from a qualified instructor can save your life.
