Disappearing Keyhole
Pat
Jun 7, 2004
1,250
The engine key seems to be disappearing back into the instrument panel so
I tried to remove the panel cover, removing the four screws (1 at ea. corner)
to no avail...there appears to be a rubberized shroud protecting the instruments from rainwater seepage.....went ahead and did start the engine,
and all went well returning to sllip, but what could be causing the key-set to go
further and further back into the instrument panel? Also what is the key to
fixing the movement? thanks for your thoughts
