tevolk
I have a '72 columbia 30 with galvanized fuel tank, our last trip out I had the fuel pick up tube get plugged and upon removing the fuel sending unit I could see what looked like flaking rust in the bottom. I pumped out the tank and when filtering the fuel I saw that it wasn't rust but what appears to be a brown film coming off of the inside of the tank. In the area that it has come off the grey galvanized metal of the tank can be seen. Has anyone else dealt with this issue? Was it a coating to seal the tank? or varnish accumulation from the fuel over many years? Not sure if I should attempt to clean the tank or remove it. Anyone remove a tank from a Columbia of the same era? The tank appears to be set in a fg well with some type of bedding compound.
Any information or feed back is appreciated.
