I have an '82
The silver legs are wooden on my boat - obviously an "upgrade" by a previous owner. The legs should lift out - you should probably use a twist-lift motion to free them - and might want to squirt a little WD-40 around them to get things going. The dinette does form a double - under the port settee should be a full-length board that has two hand-holds - pull out the wooden support bracket at the aft end, and lay the board on the bracket and a wooden "tab" in the "L." You should have two identical cushions on the port side, about two inches thick - lay the top cushion over so it mirrors the bottom, and the indention in the forward starboard corner should lay neatly along the compression post.I had new cushions made with thicker padding here - 3 inches. The second cushion now resides in the captain's berth until needed, and it makes the double much more comfortable.Hope this helps.
