I just moved my h37c to a mooring ball.What is the best way to tie off a dinghy to the mooring ball when you go sailing to avoid tangled lines and fouled props when you return?I usually sail solo so need to keep it simple.I have a 15' mooring line attached to a chain under the mooring ball and a pickup buoy attached to the end of the mooring line via a 10' line.Seems like I should attach the dinghy painter to the end of the mooring line, same place the pickup buoy is attached that way when I grab the pickup buoy I get the dingy painter at the same time.Thanks for any tips.
