Dinghy Stabilizers
122
- - Long Beach, NY
I have a 10' Inflatable with a 6 HP 4 cycle Mercury engine. Even with my weight all the way up front using a "tiller extension" I have a tough time getting the boat up on a plane. I recently purchased a Stabilizer Kit from my Mercury dealer. He claims it will do wonders in getting the boat up on a plane. Before I start drilling into my engine, has anyone had any luck with these types of devices.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Maybe not enough power
I wouldn't think a 4-stroke six would plane an inflatable. Is it a RIB, or an inflatable keel, or what? I have an 11' RIB, and it will plane with my 15HP two stroke, but not with four people in it.
Peter
Planing
I had the same problem with my 9'4" HPIF Zodiac with my 6HP Evinrude 2-strk. The 6 was just not quite enough to get it up. I bought the doel-fin type and mounted them on the OB's cavitation plate as per instructions. These things will reduce the throttle required to MAINTAIN a plane, but you need to be able to get up on a plane in the first place for them to work. If you can't get up without one, installing them only adds a little more drag, and slows you slightly, still preventing you from getting up.
Steve
Tilt adjustment?
I have a 9 foot Avon inflatable with plywood inserts for the floor with a 3hp 2-stroke outboard. When I use an extender on the steering handle I can plane (and I weigh 220lbs). Check your motor tilt adjustment and placement of the fuel tank. Maybe I can plane because I have a flat bottom? Another consideration is a 4-stroke outboard weighs quite a bit.
