Dinghy painter length
RAD88
Dec 15, 2008
163
Hunter 30 Glen Cove, NY
I have 3 questions.
1- What is the ideal painter length for an 8' dinghy?
2- What is the ideal length for a dinghy tow line?
3- What is the best way to couple the painter to the tow line assuming spliced eyes in both the tow and painter?
Sumner
Jan 31, 2009
5,254
I have 3 questions.
If the painter is the two lines off the bow of the dinghy at the D rings (left arrow and top right arrow) I just made it what looked good. Not sure if there is a correct length?
The two lines connect......
....to three chain links. The tow line hooks to.....
........... the middle link with a carabiner. The tow line goes through the..........
.......... carabiner at the end of the swim ladder and.......
.............. up to a cleat on the side of the boat. The cleat is at the lower left side of the picture. We can then let the line out or bring the dinghy in close to the swim ladder. For most conditions we have it right at the swim ladder. That way it isn't floating around when the boat is at a stand still and the tow line isn't getting wrapped around the rudder and/or the outboard prop. Had that problem before we went to this setup.
When docking we look at the dock we are coming into and pull the dinghy up on the opposite side from the dockside and tie it off along side the boat, so that it isn't in the way while at the dock or backing off the dock.
As you can see from the last picture the tow line we use is not the small yellow poly line, but some bigger old halyard line we had. I'm also going to replace the lines on the front of the dingy. We never had any of these fail, but I don't trust that cheap yellow line.
The tow bar build is here.....
http://purplesagetradingpost.com/sumner/macgregor/outside-17.html
c ya,
Sum
Our Trips to Lake Powell, UT - Kootenay Lake, Canada - Priest Lake, ID
Our Mac Pages
Mac Links
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
I'd recommend using a longer painter, since when you're towing the dinghy, you want to have the dinghy one wave length behind the boat, and that distance will vary.
Also, you want to use a floating line for your dinghy painter and tow line. Spectra and Dymeena lines are good. Many use polypropylene lines, but these have the lowest UV tolerance.
Oct 25, 2005
735
Catalina 30 Banderas Bay, Mexico
I have 3 questions.
1- Just short of being able to foul the prop ;)
2- Varies with speed; adjust length to allow dinghy to ride smoothly ... let the stern wave push the dink to reduce load on the tow line.
3- Painter should not have eye slice in working end. You should not be towing with the painter. Tow with a bridle, tie the painter to the tow line in case the bridle fails.
Randy
RAD88
Dec 15, 2008
163
Thanks everybody. Moody - those are the same conclusions that I came up with.
zeehag
Mar 26, 2009
3,198
long enough so you do not take up all the space at the dink dock...LOL--seriously!!!!!
Oct 22, 2005
257
Hunter 44DS Redondo Beach, CA
1 - This depends a lot on where you actually need to tie up the dinghy. In popular spots with a crowded dinghy dock you want the length to be at least the length of the longest boat permitted at the dock, 14' or so. This keeps the tied up boats away the dock allowing people to pull their dinghy's in for loading and unloading. It's considered extremely rude to use a short painter in these situations.
This conflicts with the "foul the prop" limit, but there are tradeoffs, just make sure the painter is in the dinghy before you start going (I've made this mistake a couple of times).
zeehag
Mar 26, 2009
3,198
i use a net float on my painter so it doesnt have the ability to get down to my prop--works great--and since i donot tow my dink is even better---lol--is easy to apply one to the line----keeps the lines out of trouble .. lol.....gooood luck!!
higgs
Aug 24, 2005
3,704
Nassau 34 Olcott, NY
If I tow my inflatable, and I only do so in calm seas, then I like to pull the bow out of the water up on the transom. This gives less drag and also eliminates the possibility of it flipping or filling with water. I really prefer to put it on deck, even if it means I partially deflate it.
