Towing a dinghy causes a lot of drag that on a long run increases the trip significantly. I'm thinking of ways to allow you to get the dinghy out of the water to reduce the drag and yet still be towing it. A couple of thoughts are using hydrofoil wings to lift the dinghy out of the water, does anyone know the drag difference between hydrofoil wings and the dinghy? The idea is to get the dinghy up on a plane but at low speeds. These flat bottom skiffs take very little energy to push along, so maybe a kind of sled that will plane the dinghy instead of pulling it through the water. Any ideas out there?
