Dimensions of 4 Post Bow Pulpit on 1981 27'
L
Linda
I've checked through the archives and haven't found this answer. I hope someone here can help. I recently purchased a Cherubini 1981 27'. A roller furling had been added but rather than modify the bow pulput or the furling attachment to fit properly, the furling was attached farther back on the bow. This has caused some lifting on plate in which it's attached. On top of that, the bow pulpit must have been in an accident since it is bent. Yesterday I took the bow pulpit off and took it to the welder. I neglected to mark any measurements from the boat. Didn't realize my mistake until I was at the welders and you really can't tell which posts need adjusting. Can someone provide me with the following measurements; between the 2 front posts, between the 2 back posts, and the measurement between the front and back post? Unfortunately, the boat currently is 100 miles from me and not an easy trip through downtown Chicago traffic. Hopefully, I'll be bringing it down soon to be closer to me, What I should have done, got the hint from Dan's archive post, was to make a template of the bow of the boat along with the post attachment holes. Ahhh, hind sight!
I
IslandJack
Pretty sure mine's the same
I'm lucky...my slip is at the house. All these measurements are center to center: Front to front = 14" Back to back = 35" front to back = 27" hope that saves you a trip! IslandJack
L
Linda
Thanks so much....
A brokerage near me has an 84 for sale and he was kind enough to let me get up there and measure that one. Although I was a little concerned that there might be some difference between the 81 & 84, I figured at least it's a guide. Your measurements agree with what I got from the 84 so now I feel better and a little more optimistic of the fit. Lucky you having your slip right outside your door. Thanks again.
