C
Carl Krave
Does anyone have any experience using a digital battery monitor? I sail a Hunter 380 and have the standard starter battery and house battery configuration. There is an analog gauge that came with the boat, but it's hard to read and I'm not sure I trust it. What I'm looking for is something that would show me (like a fuel gauge) how much juice I have left in my batteries. I know that I could probably use something like a voltmeter, but I'm looking for something simpler than that and I have seen them advertised in sailing magazines. Several weeks ago, in winds gusting over 20 miles per hour, I discovered that my starting battery was dead just as we were heading into our home port. We were forced to sail into our marina, and successfully docked at the gas dock under sail (more excitement than I had wished for at the end of a long day!). I'm not yet sure why the battery wasn't fully charged...it's less than 10 months old and has never given me any trouble before. One possibility is that I discharged the battery when I started the engine leaving our slip that morning. I had read that if you haven't used the engine for more than a week, you should turn the engine over several times with the seacocks closed and the "kill" switch turned on to move oil from the bottom of the engine to lubricate the moving parts before fully engaging the engine. I think I did this 4 or 5 times for 5 seconds each time. Could this have been enough to fully discharge an almost-new battery?Without knowing what caused the problem, I'm not sure I trust the battery. Is a digital battery monitor a good solution? Is there some other easy way I can check the batteries to be sure that they are still OK and fully charged?
