Need to ask 2 quick questions relating to my med size trailerable sailboat:1 - I'm mounting 2 small bronze block/pulleys on my aluminum mast and I'm wondering about "dissimiliar metals" problems. Would the bronze & aluminum effect each other thru galvanic corrosion resulting in mast corrosion problems? If so, I can put a rubber gasket between them when I mount them on.2 - I need to install two small metal "L" brackets on either side of my rudderpost on the interior in the lazarette. They'd run up & down so I can install pulleys going to a quadrant for a tiller/wheel conversion. Can I epoxy or resin these onto the transom bulkhead and not add fiberglass cloth to it? I do not want to drill my transom and bolt it thru, but want to epoxy/resin them in?Any thoughts would help...Kevin B.
