OOOH & you'll need it too!
Hi Jan!Great boat - congratulations! I live in Portland so I know what you're talking about!Anyway, there are several options for you depending on how much work you want to do & how much you want to spend. You can look at used chandleries (Admiralty Marine in Seattle is a great one) for different systems. You could get a Force10 propane heater, for example, that you can use while underway or at anchor. A drawback for me would be that it really only heats the place it's installed. I mean, the heat does permeate but the farther from the source, the colder you are (V-berth or Quarter berth for example). I, personally, like forced air heaters, such as Webasto. BUT they're expensive to buy & install. They also can run your batteries down pretty quick, whereas passive ones such as a Force10 don't use any batteries. The nice thing is that you have several outlets throughout the boat & heats it up pretty uniformly. And since it is forced air, you get nice ventilation. One more really nice thing about this kind of system is that you can sleep with it turned on with no fears of asphyxiation or fire. I'd be concerned (and maybe technically it isn't a valid concern but I'd be wary nonetheless) about any heater that's in the cabin that has a flame while sleeping. You can also look at Red Dot heaters but they don't heat while you're at anchor unless the engine's running. They use the heat generated by the engine to heat the interior. Very nice for motoring cuz it doesn't use extra fuel, battery power or anything. That might be a good one to look at for supplementing your main system. There are many different systems out there. Talk to lots of people in your area to see what they use & research each company thoroughly. Good luck & keep warm!LaDonna
