When I first got my boat there was very little diesel in the tank. I went to fill up and the fellow at the fuel dock handed me the hose and said "If you put 1/2 cup of diesel into the Bay (SFO) I am required by law to call the authorities and it will end up costing 5 to 10 thousand dollars".
He then put a bottle with suction cups holding it over the diesel vent. It fell off into the water before we had even pumped any fuel. I got the admiral to hold it in place and very nervously put in just a little diesel at a time until we had got 8 gallons in.
I wonder if it would make sense to permanently install a bottle on the inside, close to the point where the vent line goes throug the hull to capture any liquid that goes up the vent pipe. It could have a drain for routine removal of liquid.
It would also serve to capture any water that by some strange circumstance made its way from outside to inside.
Does anyone know if something like this has been done already or what the down side might be?
John Brecher
John Brecher
