Diesel trouble HElP?
I am trying to remove it again for testing but it will not come out.
Perhaps it does not want to be tested again... What did you do to it last time?:yikes:
It is often the simple things that hold you up...
  • Are all of the bolts and nuts that hold it in place released?
  • Does the pump have a specific rotational position that is needed on the cam to allow the pump gear shaft to be removed?
  • When the unit was installed the last time, did anything bind as it was being installed?
  • Are there any hoses/pipes connected that are restricting removal?
