Diesel temperature?
John
I have a 5411 12hp diesel in my 1980 Catalina 27 and it runs great. In my old Catalina diesel manual they say that the normal running temperature should be between 130 to 160 degrees. But I was told by a professional mechanics that the working temperatures are more like 150 to 180 degrees. I do know that it is better to run a diesel hot than run it cold. Has anyone else been told to run their 5411 at 150 to 180 degrees? Thank, John
Bob Camarena
Lower Range
There's a bit of a dilemma here in that, although Diesels like to run fairly hot, the 5411 is raw water cooled and there's a threshold at which the salt and other minerals will precipitate out and clog up your water passages. I believe that it's around 176 degrees or so, which leads to about 150 being optimal. Although the engine would be very happy with the 150-180 range, it would result in precipitation and ultimately in clogged water passages. If you watch your gauge, you'll notice that the temperature will fluctuate +/- 15-20 degrees or so as the thermostat lets in more or less cool water. This is especially noticeable before your engine block's mass heats up and stabilizes. Additionally, the 5411 cooling system (I assume the 27 is the same as the 30) is a bypass system that re-circulates the heated water and only lets in the cool water as it needs it. Therefore, when the engine is cool, very little water will come out of the exhaust. Even when it has reached operating temperature and is in a steady state, it doesn't exhaust as much water as other boats. Don't worry, it's normal, but you'll get a lot of helpful warnings from other sailors. You'll also get a bit of white "smoke" that's really steam.
Dave Slepoy
temp
I was told that most engines run from 160-180 as a norm. Overtemp happens at@ 190. I am in the Lake Erie area so we are not effected by salt. If you are concerned I would disassemble the heat exchanger from both ends ans clean good, make sure ALL lines from the impeller is cleaned of ANY rubber pieces, this will make sure that the water flow is constant and not blocked
Bob Camarena
No heat exchanger
The 5411 setup doesn't have a heat exchanger. The raw water circulates directly through the engine block, hence the need to keep the temperature down a bit from what otherwise would be optimal operating temperature.
