Hello, I have recently removed my diesel tank and clean it out. Based on the stuff that was in side, it was probably the 1st time it had ever been done. This is something I'd recommend, if you don't know the maintenance history of your boat. Anyway, I had removed the tank guage to drain the tank. There is a rubber or neoprene gasket that helps seal it, along with 5 screws. What is the best sealant to use to put it back together? And what procedure should I follow to ensure a good seal? I don't want the cabin smelling like diesel. Thanks,
