I don't think there is much
you could add to your tank, at this juncture, that would improve the life or quality of the fuel currently in your tank. And adding stuff now might make things worse. What I suggest is seeing if your primary fuel filter has a glass/plastic bowl to see the condition of your fuel. The Fram filter on my boat doesn't have a bowl, but does have a drain nut at the bottom of the filter. Drain out some fuel if you can, leave it in a glass jar for a few hours, and take a look at it. If its clear or amberish with no crud visible, its probably ok to use. If its darkish or cruddy looking, you may just have to drain the tank or have a fuel polisher treat it for you. Most likely, if the PO just put some fuel in last year while showing the boat, he probably didn't put much in -- you may want to ask him.If the fuel looks ok, I suggest that you change the primary and secondary filters, bleed the system, and start up the engine when you are in the water, of course. If it runs ok, I would change both filters again after the 2d or 3d hour of operation, just to be sure. Good luck with the new boat.
