Similar Problem
Jaydog,I've been having a similar problem with my Univ 25XP.When it's been running for a while (a couple of hours), when I back the throttle off to put it in idle, the engine stalls. My problem is then having difficulty restarting. After the stall, the temp does climb to 220-240F (after running 160-180F), but I attribute the rise to the fact that cooling water stopped and I have observed that the temp does not rise until AFTER the stall.The first time it stalled I changed all the fuel filters, bled the system and she still wouldn't start. The impellers are brand new and the pump was fine. When I tried to turn her over, it was like something was loading the engine down; the starter could barely turn the crankshaft.The stalls always happen at an inopertune time - like when trying to anchor or turn down the row in the marina to my slip. I had a diesel mechanic look at it a week after the first stall. Unfortunately, we couldn't duplicate the stall, but we didn’t run it that long. He did clean a little algae out of the fuel pipe in the tank.Of course the next time out she stalled again, after running for over two hours at 80%, BUT, here's what worked.1. To restart, I held the decompression lever, cranked the starter to get it really winding up, and then let the decompression lever go. It turned right over.2. THEN, once I got her restarted, I let her idle for about fifteen minutes until the temp came down to 160F ish. I switched it off and it restarted just fine (no “loading”). Since then I always slowly ease the throttle back for several minutes, allowing the engine to cool to 160 before going into neutral. It has not stalled since, but does anyone know what is causing this?
