Well I've been out sailing a few times. There seems to be a persistent diesel smell in the boat. When the seller delivered it, there was about a cup of mixed fuel and water under the stuffing box and engine. It was a warm day and a long road trip and the tank was full. I cleaned that up and went sailing. After a day of sailing with some motoring I found some leaks from a loose bleed fitting on top of the fuel filter and from the fuel line fitting (exiting I think) from the filter. I tightened everything up and cleaned the whole area in the picture with formula 409.
After the thorough cleaning, we ran the engine again and found no leaks. I thought I had this licked. We returned to the boat a week later and I found the area in the picture with a thin film of diesel.
It's been cold here. Do these engines hold fuel under high psi with the engine shut down? If so could it be that in combination with temps in the 30s that the fitting contracted and fuel weeped out? And what about that smell? Does it ever go away after the source of the leak is discovered and fixed?
Thanks
Joe
Thanks
Joe
