diesel problems
Rob
I posted this awhile ago and thought I would send a follow up photo to the group.....we are engine less,,,,,still debating a rebuild or a replacement..getting the finals now..compression tests on ALL cylinders failed. Diesel problems Submitted by Rob on 07/07 at 01:44PM regarding Morgan Perkins engine Sloop. Well we are back from 2 weeks on the water....2 days of which had great wind!. Question for the group. on our return trip we developed 2 problems......1.. we had blue smoke coming out our exhaust..in access of usual......Our mechanic on first hearing of this is thinking ring job.......but the second problem was blackish smelly smoke coming up from our compainionway from the engine.....upon opening the compartment..there was rubber dust..I thought the belt was readjusting itself since I had just installed a new one...but as we progressed the compartment filled with black oily residue.......We thought exhaust leak......But after further discussions belive it is unburned diesel fuel that has vaporized..the cabin filled with this stuff....we shut down and had to be towed back in.....the black "oily" substance is everywhere...in all interior compartments.........We are looking into alot of senereo's the largest is engine replacement....we have already rebuilt this engine....the engine is almost 20 years old......(Perkins) ..in the course of its life the "previous owner" (whom I hold no trust in) said it sat for 10 years.engine hour meter is only 700 hours....but it runs as though it was beat to death...... So the question for the group..what is the oily residue in our cabin. Post note:...water temp/ oil pressure gauges and tach all read norm..dip stick before starting was fine...antifreeze good...sea strainer clear...charging systems all were ok.....just smoke....havent tried to start it since we were towed in...thanks for your help. Rob
