Ray
All, I noticed a coolant leak on my engine, but I am not sure of the source. I have a very slight stream dripping down into the bilge right where the transmission mates to the engine, and it does not start until the engine is heated up and the coolant has a little pressure. As far as I can tell none of the hoses are loose and leaking and from the top of the engine there is not indication at all of coolant leaking. Only other thing there is the heat exchanger, which again from visual inspection does not appear to have a leak. Any ideas on where I should look next?
