I recently rebuilt a YSM 12. I put it in the boat and it ran while I sprayed WD40 in the intake. I traced the problem to the injector. IT IS NOT PUMPING. I took it out and went through it so many times I don't even have to look at the book to put it back together!
I took it to a shop in San Antonio and they couldn't test it, didn't have the right adapter plate. I have submersed this pump in diesel and bled it and pumped the plunger over and over. It will not push fuel through the high pressure side. Everything looks to be in good shape.
My question is this, to any one with knowledge of this type injector, IF I do not replace the internal copper washers after I have disassembled the pump and reassembled it, will the pump not seal on the inside? And how can I tell where the things is leaking from?
